happy1426
i have the skid out to replace all wheels n bearings n bushings question is what size sockets to take of rear axel?? And what do you guys usually torque too? Thanks
IH8CROWS
17mm on one side 19mm on the other. 54ft pounds.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
1 1/4 and 1 1/16 60 ft lbs
happy1426
Not a chance bud biggest socket I have is 24mm and its way to small for the small nut I just got some bigger sockets here from a friends thanks for torque specs!!
That is correct for 06-10 only.17mm on one side 19mm on the other. 54ft pounds.
IH8CROWS
I just checked my addendom for 2011 and up and it still says 54ft pounds. Maybe the nuts are different size on the newer ones can't remember from when I messed with mine.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
20 mm axle's shaft is 17mm head and 19mm nut, 25mm axle's have a 1 1/4 nut and a 1 1/16 head.
ranger1
Thats strange because I know I used a 17mm & a 19mm to loosen my rear axle to install the star linkage kit on my 2012 , hmphNot a chance bud biggest socket I have is 24mm and its way to small for the small nut I just got some bigger sockets here from a friends thanks for torque specs!!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
XTX has a 20mm axle,Thats strange because I know I used a 17mm & a 19mm to loosen my rear axle to install the star linkage kit on my 2012 , hmph
20mm axle is solid
25mm axle is hollow
ranger1
So does the mono suspension use the different 25mm axle as opposed to the XTX?XTX has a 20mm axle,
20mm axle is solid
25mm axle is hollow
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
yes. the mono 2 has a hollow axle.So does the mono suspension use the different 25mm axle as opposed to the XTX?
Winderallday!
For the 128" mono/megafloat guys with the larger hollow axle, be sure and tighten the axle nut on left side after any suspension wrenching, had a buddy that lost two of those expensive nuts along with the outer wheel on the trail, they back off easily if not tightened to torque spec.
Fortunately, I was following each time and saw/retrieved the wheels, but the nut......she goonne!
IH8CROWS
Just checked my 2015 xtx and the nuts are 17 & 19mm.
canadian nytro
- Dec 3, 2009
- Port Perry, ON
- 2011 Yamaha Apex
2002 Yamaha Viper
My 2011 apex SE use a 32mm nut and on the shaft i used a 1-1/16. Fits perfect just went out in the garage to check for you.
Bucky the d.o.g.
- Oct 8, 2007
- Ottawa, Ontario
- 2017 Apex XTX
32 mm socket left side and an 1inch adjustable wrench on the right side
