uofm
On my ride in the deep snow the front end of my XTX completly filled up. What is the best fix for this?
towerrigger
I went with pre filter from slp. It comes in different sized sheets. Here is the link to my sled in the garage. Bottom of page has the pre filter I'm talking about.
Daranello
Suspended
no kidding
Nikolai
Pre-filter material over the two hood vents and side panel vents. Duct tape over the vents in front of the oil tank and the vent under the headlight. Sticky back Foam on both sides of the headlight. The above will keep 99% of snow out. I rode all day today in powder and didn't get hardly any snow inside. You can buy the pre-filter material in an 18" square from Ski-Doo which is enough to do all four vents.
First pic shows the four vents with pre-filter material
Second shows the foam around the headlight
acesfan05
I ride in deep powder a lot with my Nytro. I have never overheated. I don't mind snow everywhere. We love it when we find untouched 4 plus feet of powder in Alaska
Snoxracer242
The snow in the engine bay doesn't bother me half as much as the snow on the running boards does. Riding in deep snow with my Nytro 121" snow will shoot straight up thru the holes in the boards. It is not a deep snow sled in my opinion, at least not the RTX
KINS
Nikolai said:Pre-filter material over the two hood vents and side panel vents.
In addition to the pre filter material as described above, I also used it on the grilled section at the bottom of the head light.
If you look at the pic above you will see all kinds of spots where the nose piece has parts like the bumper going through it. I found that sealing these spots on the inside with clear silicone caulking helped a lot.
clicker_clit
Switch to a wider ski. I use a C@A ski but the simmons are a good ski to. The yamaha snowmobiles are not very well balanced front to back and tend to be nose heavy. They are harder to ride in deep snow because they dive all the time. I had the same problem you had this weekend with the heavy wet snow in the ditches. I was able to keep the front end on top of the snow most of the time since I had the C&A ski. The stock yamaha skis are to narrow and throw alot of snow back at the machine.
Deadman
Thats like shooting yourself in th efoot, because the radiator is under the hood. You need max airflow for that too. The prefilter is good, but blocks some air. can't win!
Nikolai
The MTX's have an additional cooler in the tunnel. I have never had any overheating issues.
towerrigger
I have never had an issue with overheating yet. I don't ride trails though so it may overheat with a lot of trail riding. Surprisingly the pre filter flows a lot of air as long as you clear the snow from it.
