Swiss Sledder
Clutching
How to change your belt
Helix # Reference Charts
How to install a Ulmer Clutch kit
DO NOT ROTATE CCW when changing clutch parts
Exhaust
Exhaust Donut Replacement Procedure
Change the Fuel CO Settings on the Nytro
Engine
Starter Gear & One Way Clutch Inspection
Frame
Nytro Subframe Removal Procedure
Torque Specs
Drive Shaft Torque Specs
Nytro Torque Specs
Electrical
Starter Problems & Questions
Starter System trouble shooting
Info on Error Code 67
Nytro Fault Codes and Relay Location
Install Vector Gauge on Nytro
Install Vector Gauge on Nytro Ver2
How to test my AEM Air Fuel Gauge
Fluids
Oil Change Instructions
Video: Step by Step Oil Change
Oil Pressure-Diagnosing engine after loss of oil
Fuel Mileage
Fuel Level in Tank for each bar on gauge pod
Fuel Mileage Reports from TY Members
Real World Fuel Mileage
Fuel Tank Options
Clear Tank: extra fuel and installation with pictures
Extra Fuel Tank
Removing Fuel Tank Sleeve
FX Nytro Miscellaneous
Feedback - Apex Owners Switched to Nytro
Feedback - Phazer Owners Switched to Nytro
Owner Photos
Sled Weight and Horse Power numbers
Top Speed
Who Loves Their Nytro!
Wire Rub Fix with Picture
Yamaha Technical Manual On-Line Order web site
Portable Jump Packs
Paint Codes
Handlebars
Handwarmer Fix from Bluballer
Handwarmer Poll
Handwarmer Resistance Tests on 09 Models
Kill and Dimmer switch Part #'s
Headlight
HID Bulb Reflector Mod
Bulb Size
Headlight beam adjustment procedure
Hid vs Halogen
Hyfax, Belts
Detailed Hyfax Wear Fix
Adding wheels to XTX for better hyfax wear
Belt Options
Hyfax wear opinions
Left Boot Syndrome
Fix for Wet Left Boot Syndrome
Wet Left Boot Discussion
Modifications
Front End Ball Joint
Install Heated Shield Hook Up
Removing heat exchanger with pictures
Spare Belt Holder
Tether Installation Instructions with Pictures
Tool bag
Ride Report
Alaska Early Season 2007 Ride Report and Second Ride Report
Member Test Ride Report
Official TY Ride Review of 2008 FX Nytro
Yellowknife's Season Ride Report
Shocks
Adjusting GYTR Dual-Clicker shocks
Fox Floats: Pros and Cons
Fox Float PSI Setting Survey
Skis
Mod to install a Polaris Gripper Skis
Best Skis?
C&A's
C&A's with picture of mounts
Suspension
141" Viper Skid Install into Nytro
XTX Suspension Setting
08 to 09 Suspension Changes
09 Changes
Crucial Suspension Changes to Make Your Nytro Rock!
Limiter Strap Fix
Need help getting a softer ride
RTX Suspension Settings - I nailed it!
Suspension Settings That May Help
FX Nytro settings POST YOURS
Suspension Troubleshooting Chart from Snowest Magazine
Track & Gear Case
Video: 09 Nytro Chain Case removal / Assembly
General Bearing Maintenance
Bearings: Jackshaft and Trackshaft
Understanding Track Length and Pitches
Adding Extrovert Drivers
Track or Gear Change Instructions with Pictures
Track or Gear Change 2nd Thread
Track Options
Windshields
Pictures of tall windshield and side deflectors
Performance
Supercharger Install
Supercharger Pulley Install
XTX Specific Threads
Suspension Settings
Exhaust
Engine
Frame
Torque Specs
Nytro Torque Specs
Electrical
Fluids
Fuel Mileage
Fuel Tank Options
Extra Fuel Tank
Owner Photos
Top Speed
Portable Jump Packs
Paint Codes
Handlebars
Handwarmer Poll
Headlight
Bulb Size
Hid vs Halogen
Hyfax, Belts
Belt Options
Hyfax wear opinions
Left Boot Syndrome
Modifications
Spare Belt Holder
Tool bag
Ride Report
Shocks
Skis
Best Skis?
C&A's
Suspension
09 Changes
Limiter Strap Fix
Track & Gear Case
Track Options
Windshields
Performance
Suspension Settings
rage man
u should make it so that the links just show all the fixes not all the chatter aswell lol i know thats would take a while i dont care that much i was just th8inking of the newbies also i probally not suppose to post here i no
Nice Job Matt!!!
rage man
oops forget to say
its a good job
its a good job
couch
Great Job!!!
Great work!!!
I wish more people would check this out before repeating the same topic over and over. lol
Yellowknife
Sweet.
dependableskidoo
- Mar 19, 2009
Very new to this site, just traded my XP renegade on a Nitro...great motor, and I have lots to learn...
Craig
Nitro XTX 175 miles
2008 Renegade SDI X 2640 miles and 11 trips to the dealer
Craig
Nitro XTX 175 miles
alsops
- Feb 17, 2009
- Headingley, Manitoba, Canada
- liverpool.com
- 2009 Nytro XTX
2021 Sidewinder XTX LE
09 XTX
When would the 09 XTX service manual be available on the site?
Pratas
2 Swiss Sledder
Thank you very very much. A lot of useful information sorted! Respect!
big_red1a
Can someone add the measurements for extrovert drivers
I just added it based off your other post.
pro116
big_red1a said:Can someone add the measurements for extrovert drivers
Its diffrent depending on what style of drivers
- 146K
- 46K
- 31K
