Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Switched over to G-Force, before the second break-in cycle the belt started squealing on take off. Fix deflection, keep riding.
After second heat cycle it let out a short squeal while throttling in reverse. Did it one other time. Curious as what that might be?
Never did it B4, and I used reverse with XS825 two weeks ago.
Bar hopping Southern Wis. Never know what you're gonna find.....'24 900turbo. Absolutely gorgeous sled. No Boosts or Comp850's to antagonize. This was definitely Cat country. It was an infestation. No Yamahas to be found all day.
I would guess you need to adjust your belt again. Still too loose.
Doc Harley
- Oct 17, 2016
- Here & there
I'll give her a twist tomorrow, Tom...ty.
