Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Hello checked oil in my sled yesterday and when I unscrewed dipstick oil ran out tank was right to top stunk like gas ,now I have bigger fuel pump ,bigger injectors stage 1mpi supercharger running 12 pounds of boost head shim ,what could possibly be wrong it idles like its overfueling ,have pcv which I think works pretty darn good has anyone had the fuel pressure regulator fail ?leaky injector maybe ?so I changed oil ,filter drained everything went for a 25 km ride burnt half a tank of fuel checked oil in it this morning and tank is almost right to top again and stinks like gas again anyone else ever have this
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
It's a 2006 apexHello checked oil in my sled yesterday and when I unscrewed dipstick oil ran out tank was right to top stunk like gas ,now I have bigger fuel pump ,bigger injectors stage 1mpi supercharger running 12 pounds of boost head shim ,what could possibly be wrong it idles like its overfueling ,have pcv which I think works pretty darn good has anyone had the fuel pressure regulator fail ?leaky injector maybe ?so I changed oil ,filter drained everything went for a 25 km ride burnt half a tank of fuel checked oil in it this morning and tank is almost right to top again and stinks like gas again anyone else ever have this
YamerHammer
You are over fueling......what is your afr's at? I am running a supercharger as well......what are you running for pulley's? I am running 22 28 which to me looks like on gauge to be 13lbs but hard to tell and I'm not out of scope on the stock injectors. I also am running the pcv.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Hi I am running 26 bottom 22top which is 12 pounds of boost my afrs is at 5 at about 1/2 throttle and 13.9-14.9 at wide open would you be interested in sharing your pcv mapYou are over fueling......what is your afr's at? I am running a supercharger as well......what are you running for pulley's? I am running 22 28 which to me looks like on gauge to be 13lbs but hard to tell and I'm not out of scope on the stock injectors. I also am running the pcv.
YamerHammer
That is actually 10lbs of boost,if you take your boost readings from behind the throttle plates you will see.......you absolutely do not need those injectors. My map is no good to you with the injectors you have in. I also have a tps voltage clamp. Sounds like you're AFR sensor might be bad, giving you false readings. Mine did that to me as well. They don't last to long due to the rich condition that they are in. Well at least that's my theory.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
O
okay thanks for the infoThat is actually 10lbs of boost,if you take your boost readings from behind the throttle plates you will see.......you absolutely do not need those injectors. My map is no good to you with the injectors you have in. I also have a tps voltage clamp. Sounds like you're AFR sensor might be bad, giving you false readings. Mine did that to me as well. They don't last to long due to the rich condition that they are in. Well at least that's my theory.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay thanks for the info ,ya I am going to order a new afr sensorThat is actually 10lbs of boost,if you take your boost readings from behind the throttle plates you will see.......you absolutely do not need those injectors. My map is no good to you with the injectors you have in. I also have a tps voltage clamp. Sounds like you're AFR sensor might be bad, giving you false readings. Mine did that to me as well. They don't last to long due to the rich condition that they are in. Well at least that's my theory.
rat4020
- Oct 28, 2011
- Cold Spring Minnesota
- Polaris and Turboed Apex in a off road buggy
I had the same thing going on with my turbo Apex 10lbs with stock injectors . The oil smelled like gas & when I ran it WFO there was a lot of oil blowin out the crank breather . I chased that gremlin for a year and finaly found that my TBIs where not sealing to the intake causing a very rich reading on the AFRs and wrecked the O2 sen . I reworked the TBI boots and added a bracket from the head to my plentum that was the end of the problem . Now there is no oil coming out the breather and I had to turn my boost way down to stay at 10lbs . I am using a Bosh O2 sen and you can buy them at about any auto parts store
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay
thanks I will check that out , I looked at the boots on the weekend and they seemed nice and snug, where did you get your wide band sensor fromI had the same thing going on with my turbo Apex 10lbs with stock injectors . The oil smelled like gas & when I ran it WFO there was a lot of oil blowin out the crank breather . I chased that gremlin for a year and finaly found that my TBIs where not sealing to the intake causing a very rich reading on the AFRs and wrecked the O2 sen . I reworked the TBI boots and added a bracket from the head to my plentum that was the end of the problem . Now there is no oil coming out the breather and I had to turn my boost way down to stay at 10lbs . I am using a Bosh O2 sen and you can buy them at about any auto parts store
rat4020
- Oct 28, 2011
Okay
My first one came with the auto tune and the replacement one I picked up from CarQuesr auto parts .
Just take you old one out and bring it with you I am sure some parts store in your local will have one
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay thanks I will check into it
