crossroadz
I installed the auxiliary heat exchanger on my XTX. Fairly straightforward install - just had to remove the seat, tank, and lower the track. I was getting the engine overheat light last year. It may have been from ice build up under the tunnel but I thought the auxiliary heat exchanger would help.
pete24
i put one in my 08 didnt lower the track just used a pry bar to hold it tite against the tunnel while i riveted it, worked very good never got the over heat light again, i put 5000miles on that set up
Tyloooor
I had the same issue with my overheating light coming on last winter....put the heat exchanger in and never had an issue since....they should come from factory with one...just watch the hose clamps, they work themselves loose.
00-NUKE
crossroadz said:I installed the auxiliary heat exchanger on my XTX. Fairly straightforward install - just had to remove the seat, tank, and lower the track. I was getting the engine overheat light last year. It may have been from ice build up under the tunnel but I thought the auxiliary heat exchanger would help.
What did it cost? I've been thinking about doing the same thing. The only time that mine gets warm is in the Pow.
mpi xtx
Forgive my ignorance but is that the MTX cooler? Looks like that will do the trick. I am looking at adding some extra cooling on my newly aquired 09 XTX.
raginyamaha
mountaintech has a nice one that is twice the size of the stock one. good price too00-NUKE said:crossroadz said:I installed the auxiliary heat exchanger on my XTX. Fairly straightforward install - just had to remove the seat, tank, and lower the track. I was getting the engine overheat light last year. It may have been from ice build up under the tunnel but I thought the auxiliary heat exchanger would help.
sheetwright
That should help a lot. Van amberg has one for the shorty and XTX also. Helps big time with the famous Nytro rear build up by the snow flap. with this you get piping on the one side, and the rear covered.
dubweiser
my 2013 xtx has the exchanger in it from factory...still over heats in low snow conditions on occasion
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Swap out your coolant for a 50/50 mixdubweiser said:my 2013 xtx has the exchanger in it from factory...still over heats in low snow conditions on occasion
radianguy said:Swap out your coolant for a 50/50 mixdubweiser said:my 2013 xtx has the exchanger in it from factory...still over heats in low snow conditions on occasion
I put the auxiliary cooler in last season with 50/50 mix and still had the light come on...kinda has me baffeled
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
I had the same issue last year when the trails were frozen up. I would break off trail into the loose stuff to cool down. It never took long for the light to go out when I did this. This year I have picked up a pair of scratchers to help out when the trails get tough.dubweiser said:my 2013 xtx has the exchanger in it from factory...still over heats in low snow conditions on occasion
crossroadz
Its the auxiliary cooler from the mountain sleds and cost $280 from my dealer although I think it lists for $420. This season I'm gonna check for ice buildup under the tunnel.
Mountaintech
R00STER said:I had the same issue last year when the trails were frozen up. I would break off trail into the loose stuff to cool down. It never took long for the light to go out when I did this. This year I have picked up a pair of scratchers to help out when the trails get tough.dubweiser said:my 2013 xtx has the exchanger in it from factory...still over heats in low snow conditions on occasion
The scratchers will do the trick.
Mountaintech
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Mountaintech. Will these work on a 121 an fit fine? Also to he guys with cooling issues. Are u running studs?
