TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
When you are doing the regrease on the secondary and drive shaft bearings (all on clutch side)
Cover the bearing with a clear container with a small hole on the side or front to use compressed air.
Large one for secondary and a smaller one for the drive shaft.
If you don’t cover them up the old grease flies all over. I use to use a rag but that still makes a miss.
TOMBOB
TOMBOB
