edge_232
- Jan 15, 2014
- Madison WI
- 2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
I believe the ballast to my right head light has burned up. I can swap the bulbs and the one on the left side always works. I also checked power to the ballast and I'm good there but nothing coming out of it. So in my mind it's bad. Now here is my second problem I have no idea who's kit it is or where to start looking to replace it. Here's a few pictures of it and if you guys know who's kit it might be please let me know.
Edge
Edge
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Yep, sure sounds like a DOA ballast. If it's a Fleabay set, doesn't surprise me as I had the same issue. You could just get a pair from Fleabay as replacements. Consider these CCC ballasts as disposable. You could get better ones but, like anything, you'll pay for it.
edge_232
- Jan 15, 2014
- Madison WI
Ya I have no idea where these came since there were on my old nytro that someone else installed then relocated them to this one. I need find out if their 35 or 55 watt as well so I can get the correct ballast.
Thanks for the heads up.
I think they may have come from a vendor on TY possibly.
edge_232
- Jan 15, 2014
- Madison WI
One more thing both HID bulbs are run off of just one stock bulb plugs. Seamed strange to me but I never messed with them before.
Contact Rockmiester... he might be able to help you out.
edge_232
- Jan 15, 2014
- Madison WI
I'll do that.
edge_232
- Jan 15, 2014
- Madison WI
PM sent, Thanks
edge_232
- Jan 15, 2014
- Madison WI
Rockmiester got me all taken care of ! Thanks guys
Awesome!! I new he would.
NS FX NYTRO
Only one headlight plug need to be plugged into harness. That is correct, this simply controls the hi/lo beam feature.
Unless you use Rocks patch cables...
NS FX NYTRO
True.
I should have quoted the OP's post, as I was referring to his question
edge_232
- Jan 15, 2014
- Madison WI
Now if you use rocks patch cables could i put his HIDs in my IQR? With the patch cables you don't need the 12v power.
And yes I know I own the two biggest money pit sleds out there LOL!
I would contact him to be sure it will work in a 2stroke.
