Ethan_Messinger
- Jan 17, 2016
- Wisconsin
- 2011 Yamaha Nytro XTX
Putting an HID kit in my buddies nytro. Anyone have instructions or a link to another forum post about how to install? It’s the kit from “headlight experts”. Will we need to run anything to the battery, or will it all run off the factory headlight power? Just super confusing, and I have the kit in my Nytro, but it came installed... I can do a lot to these sleds but this has me stumped.
dennyboy
- Oct 4, 2013
- Minnesota
- 2012 nytro XTX 1998 srx 600
you need an H4 kit for the nytro. just did hids on my sled. i used a kit from DDM some are plug and play. usually the 35watt kit is plug and play. 55watt kits usually pull power from the battery but use the factory harness to trigger the relay. still mostly plug and play but you have to hook up power and ground to the battery... hope that helps.
Ethan_Messinger
- Jan 17, 2016
- Wisconsin
Thanks! Looks like I figured it out. It’s weird cause it only had 1 connector to the factory headlight plug in, and then 2 ground wires. So 1 of the factory connectors isn’t plugged into anything, but it all works! Oh and yup I had to run a wire to the positive terminal.
markyb
- Feb 6, 2015
- Twillingate, NL
- 2009 Nytro XTX
- Twillingate, NL
Your power is being taken from the battery in this case. The one connection to the factory harness is the trigger.Thanks! Looks like I figured it out. It’s weird cause it only had 1 connector to the factory headlight plug in, and then 2 ground wires. So 1 of the factory connectors isn’t plugged into anything, but it all works! Oh and yup I had to run a wire to the positive terminal.
Good info to know if you need to troubleshoot down the road.
