Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Just went to pack some extra grease into the jackshaft bearing, at the clutch end, and could actually lift the shaft a bit in the bearing. The bearing is definitely worn and needs replacement. What is the easiest way to replace this bearing? Does anyone have cross reference numbers for a bearing supply store, rather than Yamaha original parts?
yox185
That's one bearing I would use OEM to replace. It's a bit of a job to replace so you're going to want a quality part.
http://totallyamaha.com/snowmobiles/aaTECH/Jackshaftreplace/Jackshaftchange.htm Here's the procedure.
Dmaxxer
I tried to find a replacement bearing and wasn't able to at a bearing supply store. Just buy the Yamaha bearing.
Roger
- Feb 10, 2007
2006 Indy 500
Thanks for the advise. I was hoping for an easier fix than dismantling the chaincase, and a cheaper bearing than Yamaha, after all, Yamaha doesn't actually make any bearings.
Thanks again.
Roger
Thanks again.
Roger
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Roger said:Thanks for the advise. I was hoping for an easier fix than dismantling the chaincase, and a cheaper bearing than Yamaha, after all, Yamaha doesn't actually make any bearings.
Thanks again.
Roger
I don't believe you need to dismantle the chaincase if you don't want too.
Maybe do a search as I believe lots have changed out this bearing quite easily without getting into the chaincase.
I haven't had any problems finding a quality replacement bearing. You can purchase from Yammy but they don't make them.
YammyRX1
I could be wrong but I doubt Yamaha orders special higher quality bearings from the manufacturer. They might specify seals on one side or have a special tapered inner race but this is all available aftermarket for a fraction of the price. I bought kits that contained all seals and bearings for both shafts for under $100. Sent you a PM
Roger
- Feb 10, 2007
2006 Indy 500
Thanks for all the info. Still looking for an easier way to change this bearing.
YammyRX1
Did a few searches here and the only method that I saw to remove the bearing without touching the chaincase is to tack weld something to the bearing and use a puller.
Roger
- Feb 10, 2007
2006 Indy 500
Thanks for the reply. I will attempt to remove the wedge, and then possibly get an internal bearing puller in there, to get the bearing out.
Roger
Roger
Ebrown70
- Nov 19, 2017
- lowell indiana
- 07 vector, 08 apex ltx, 03 rx1 ,05 warrior
and a fleet of 06's & 07's Apex's that the family members own
This time of the year we see about 2 a week on Yamaha 4 strokes , with jackshaft bearing failures,
have switched to using a better bearing , and still testing the built in collar design on my own sled , like the clutch side driveshaft bearing uses. getting away from the taper collar with spanner nut that keeps coming loose ,
Ebrown70
- Nov 19, 2017
- lowell indiana
shed
my 07 has that tapered inner race bearing also
did mine 2 times at 9150 and at 18500
first time the bearing spun on the shaft, had to frankenstein it back together
2nd time replaced the shaft, wow $450 in canada
my 2011 has the other bearing/mount system, not the tapered
yeah
yeah
