kinger
Does everyones spin with the secondary? I got mine tight but I can't remember if they turn with the secondary or not, mine spins right along with the secondary. Thanks
VT_BluYamaha54
- Dec 20, 2003
- Vermont
- 2012 Vector LTX
2004 RX-! Warrior
1984 Phazer (Antique)
Are you asking if the collar turns with the shaft/secondary?
YES. But bearing outer should be tight in the cast member and NOT turn.
Mikey
If the collar didnt run with the secondary it would be spinning on the shaft and that would be very bad and the reason some of the 03's shafts failed as the collar cut thru the shaft. The inner race of the bearing is fixed to the shaft the outer race is fixed to the sled.
kinger
Got thanks, I'm just paranoid, we lost on on a vector with 900 miles because of a faulty install by the dealer so I'm just double checking, thank you!
