DelgatyXTX
About a year ago I saw a bracket someone had fabbed and was selling that you mount the K&N filters to so they don't fall off. Does anyone have any info on this? I tried a search but found nothing.
Thanks,
Ryan
Thanks,
Ryan
DelgatyXTX
Did a Google search instead of on here and found it.
Sorry for taking up 1st page space.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I remember the post from someone who fabbed a bracket from Aluminum but I'm not sure he was fabricating any for sale. I just made a harness out of large zip ties for mine. Did a full season and they haven't budged. I basically put one zip around the top of each one loosely then connected one to another (similar to chain link) and tightened them. Then anchored the outter ones to the frame on both sides. It's almost invisible but functional and pretty well zero weight. Hope this helped.
DelgatyXTX
I should give that a try. I tried zip ties in the past but not that way. Thank you!
johnelway
On my side, i've a custom bracket.
it's just a aluminium plate bolted into the stock airbox hole and bent into L shape
so the bottom of the filter sit on the L shape
picture of a standard bracket with the good shape.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
Ryan did you see in my build how I did it? 4000 miles like that, lots of pounding and never had one come off.
DelgatyXTX
revster said:Ryan did you see in my build how I did it? 4000 miles like that, lots of pounding and never had one come off.
I checked out the thread and saw the install pics but not how you secured them. You used a system of zipties as well right?
revster
- Aug 18, 2004
- La Salle MB
DelgatyXTX said:revster said:Ryan did you see in my build how I did it? 4000 miles like that, lots of pounding and never had one come off.
Ah, I guess I didn't post a pic of that. I'll take one tonight for ya. Very simple with zip ties just tied loose to prevent them from bouncing.
