Turboflash
- Mar 18, 2019
- Southern MN
Curious to hear from others as to exact location of ball bearing that is pressed on jackshaft. I have serviced a number of local TCats and replaced that bearing. In some, that bearing is against the shoulder, in others it is about .020-.030" away from shoulder. It's like it was pressed on to a certain length dimension from end of shaft.
At the of the day, they all are functional but I wonder what the design intent was?
What have some of you observed?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I've only seen them against the shoulder. Except for the one Winder I had here that we took the snapring off the shaft to get clutch alignment and it vibrated the bearing outward as he was still floating the secondary. I now no longer remove the snapring unless bolting the secondary down solid to the shaft and dont let it float after that happened.
I know the Cat doesn't run the snapring on the shaft, but in the housing, maybe its vibrating outward that much perhaps.
NYTurbo
Only seen them against the should Winder and Cat
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Not as observant as you, but I will say that I remember something a bit strange with how my bearing fit on that worn shaft during inspection of all with new bearing in hand and not in caliper! Of course shaft was worn pretty bad twice, but if I placed that bearing on the shaft and pushed in until it stopped, that portion of the shaft was tight on bearing. Pull it back just a bit and yeah you could see the loose fit. So I said to self, Caliper doesn’t allow bearing on shaft 100% of way! That’s was with .014” of wear on shaft!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
They are speaking of the jackshaft bearing(behind secondary clutch), not drive shaft..Not as observant as you, but I will say that I remember something a bit strange with how my bearing fit on that worn shaft during inspection of all with new bearing in hand and not in caliper! Of course shaft was worn pretty bad twice, but if I placed that bearing on the shaft and pushed in until it stopped, that portion of the shaft was tight on bearing. Pull it back just a bit and yeah you could see the loose fit. So I said to self, Caliper doesn’t allow bearing on shaft 100% of way! That’s was with .014” of wear on shaft!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes I see that now that you mention it, oops my bad but thanks for bringing it to my attention and sorry if I caused the post to go sideways a bit! I haven’t had to touch my Jackshaft bearing as of yet, besides greasing it every other season.They are speaking of the jackshaft bearing(behind secondary clutch), not drive
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hey no problem.. If you service the jackshaft bearing as you do it will last a long awhile.. Not hearing to many issues with this bearing.. Probably good to do it maybe around 10-15K preventive maintence replacementYes I see that now that you mention it, oops my bad but thanks for bringing it to my attention and sorry if I caused the post to go sideways a bit! I haven’t had to touch my Jackshaft bearing as of yet, besides greasing it every other season.
- 51K
