Roost 'Er
Hi there,
Going to look at a Nytro XTX this weekend, It needs some work, however does the brake disc look normal in this picture? Almost looks like its on an angle?
Gonna take a good look at it, engine, suspension, rails, track anything else i should look at that is specific to Nytros? Ive read alot about the Sub-frames, so will look closely at that.
Thanks,
Thanks,
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Looks normal to me.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
might just be a decieving picture...
Roost 'Er
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Look down at the the front of the frame to see if it's twisted. Also check the center gusset for buckling. In the pictures you sent me it looked like the right spindle was out of alignment but it's often hard to be sure looking at a picture. http://s589.photobucket.com/albums/ss33 ... %20gusset/
2008 bent subframe:
2009 buckled center gusset:
2008 bent subframe:
rbell14
buckle
I've notice some slight buckle on mine but it does not appear visually to be bent. Will the buckle get worse or just depends on how hard I ride? Any risk is leaving it for now and monitoring it going forward?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
It will probably get worse. Most likely your shocks are not centered in the upper a-arms. If that's the case normally you can use a pry bar out on the end of the a-arms to center the shocks. Welding in gussets to reinforce the frame will prevent it from bending again.
#1Wolverine
xtx subframe
Anyone have a close up pic of shock centered in the a arms. Is it exactly in the middle
toddt
My Floats are closer to the back of the a arm they have alittle more room in the front. Sorry no pic.
rbell14
buckle
Mine are a little closer to the back vs.exact middle as well except mine has 2 slight buckles vs.the 4 shown in picture. I assume factory has 0 buckles. Can anyone confirm that?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Roost 'Er said:Hi there,
Thanks,
There should be a spacer in between the disk and the locking collar...could be your problem if it is not there.
upei93 said:Roost 'Er said:Hi there,
Thanks,
X2, they also wear and can cause the disk to wobble and rattle.
Roost 'Er
Hmm thanks for the heads up guys, missed that one but keeping eyes out in future.
sleddingfarmer
Roost 'Er said:Thanks guys, Reviewing my old notes on the Nytro's, did they update the rear suspension bolt mounts on the 2009's? I had this picture saved on my computer for reference;
This was an update they came out with for the 2009 rtx se and the xtx I believe, whichever models had the updated tunnel that year. They put that bracket on to prevent the tunnel from bending/folding right there. I brought my 09 SE in and the dealer did it for free. I think every sled after 09 had it on.
