shawnj
Was trying to back sled into trailer (first mistake) it started to slip, i could smell the rubber burning. Being a bit stubborn (second mistake) I tried again.... After that didnt work lol, i decided to do it the right way and drive the dam thing in. Well, when I got home I checked belt, hard to see any visible damage but there is tiny belt particles all down the left running board. Thoughts on leaving it on and trying it? What might I notice if it is now defective? Thank you!
Fords4life
- Dec 7, 2021
- South Dakota
Im sure you burnt it, will go thump thump.
shawnj
Eeeeee, shitty.Im sure you burnt it, will go thump thump.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Try running it.. Depending how bad you torched it? Might be okay, but if you feel it . Dump it
shawnj
Think I will do just that when I get out again. I will take it off today and do a thorough inspections to see if I can see a spot worse than the rest. Those little crumbs come from somewhereTry running it.. Depending how bad you torched it? Might be okay, but if you feel it . Dump it
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
post a picThink I will do just that when I get out again. I will take it off today and do a thorough inspections to see if I can see a spot worse than the rest. Those little crumbs come from somewhere
shawnj
Of the belt shavings, or the belt?post a pic
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
BELTOf the belt shavings, or the belt?
shawnj
shawnj
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Run it.. If it vibrates ditch it.
. I do see one spot that appears to have cord pulled?. Glazed it over good.. The only issue would be that cord or vibration. Run it for a trip and don't hammer on it right away. Then see what it looks like.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Put strawberry jam on its toast
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It's junk!
Throw it away, its going to vibrate and thump like a SOB!
shawnj
Was hoping to reinstall as I will be riding double next trip out and didn’t want to break in a brand new belt with 2-up.
At least I can always throw it in the back as an emergency back up or to use when I decide to try something stupid again..
Some advice so you don't do this again.
99% of the time this happens while trying to get the sled moving from a stand still, usually due to being froze or a ski stuck on something like a trailer ramp for example.
If you grab a bunch of throttle and the sled isn't moving you have to back out of it right away and figure out what's going on, or this is the result.
