Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
and wow . that crank is way different
Sunvang
- Jan 14, 2009
- Telemark
- Norway
- 2018 Arctic Cat Hardcore EVO
2017 Yamaha Sidewinder BTX LE
By the looks of it, the only thing that is unchanged is the crankcase. Everything else is different.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
ya i agree.
my dealer has no clue about the change
stingray719
Do those part numbers match the new Yamaha side by side?
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Don't panic.... From what I understand it is more or less the motor out of the YXR. Yamaha is gonna use the motor for a multitude of things, if you were to order a new viper motor it would have many more points to mount the engine on the case. One case/motor for many machines, great idea!!! less manufacturing costs and still a very strong engine!
Sunvang
- Jan 14, 2009
- Telemark
- Norway
Not home now so can't check. Will look when I get home for the weekend.Do those part numbers match the new Yamaha side by side?
Sunvang
- Jan 14, 2009
- Telemark
- Norway
Why wasnt the new 2016 owners told?Don't panic.... From what I understand it is more or less the motor out of the YXR. Yamaha is gonna use the motor for a multitude of things, if you were to order a new viper motor it would have many more points to mount the engine on the case. One case/motor for many machines, great idea!!! less manufacturing costs and still a very strong engine!
Allan
- checked some of the stock #'s and they mach the Vector.
yukon yamaha
- Jan 30, 2008
1
Yamadog
It is not a new engine it is still the same 1049 configuration. This has been known for quite some time. They made the changes due to vendor changes on the motor that is pulling multi duty in everything from sleds to side by side to other products so they would all have the same block and necessary mounting points and the parts supplier could not keep up with the demand of building that many motors.
http://www.ty4stroke.com/threads/do...anges-affect-viper-motor.137451/#post-1244093
stingray719
As I said in another thread, the improvements were meant for the side by side and maybe others. Who thinks Yamaha would spend all that money on upgrades to a Vector engine?
I am also told that this is what most of the changes are,
visual changes :
oil filter re-positioned
coolant hose moved
additional casting of case (2016 srv, YXR, XV1050)
new cyl design:
new camshaft caps less components
caps reduced to 3 pc design
coolant hose moved
camshaft:
new locating boss
valve timing remains unchanged
valve stem:
seals have gone to rubber with steel reinforcement
new chain tensioner with oil pressure assist (cam chain)
new cyl head cover :
oil cap moved
cover made out of alum
cap screws from 6 down to 4
crankshaft is now pressed to produce a stronger crank
connecting rods now use bolt with no nuts
Kind of looks like an engine designed for boost?
visual changes :
coolant hose moved
new cyl design:
coolant hose moved
camshaft:
new locating boss
valve stem:
oil cap moved
olie72
my dealer told me they are 8hp less then the 14,and 15's. They will get the same top speed though. he said they changed the crank to accommodate the turbo.
Yamadog
They will get same top speed with less hp? If they are selling magic beans next to then grab me a pouch
yukon yamaha
- Jan 30, 2008
The crank was changed for more strength, the horse power is within 1-2 hp..... Yamaha would not lower the total hp in the motor that all ready has stated the HP numbers.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
i sure hope they give me some more info.my dealer told me they are 8hp less then the 14,and 15's. They will get the same top speed though. he said they changed the crank to accommodate the turbo.
i dont get this at all. i just called my dealer, they have no idea. It would be nice to know if they are just going to leave me with my 2016 that isnt a 2016 anymore.
