Sportsterdanne
Im in the search for both clutches and wonder from what other models they will fit.
I belive that the secondary clutch is nytro only but what about the primary ?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I believe they are all the same on both APEX,NYTRO, and the VIPER too. The things that will not be the same is springs, helix, and weights.
Someone made a post with all the differences. Will look around. From what I recall and have seen is the Primary's all fit. Some differences are setscrews for pins,windage plates and like said all the rollers and weights.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
The secondary clutch will have to be a Nytro one, the nytro has a different diameter secondary shaft.
Sportsterdanne
cannondale27 said:Someone made a post with all the differences. Will look around. From what I recall and have seen is the Primary's all fit. Some differences are setscrews for pins,windage plates and like said all the rollers and weights.
You mean the Primary from all 4 strokes (Apex, RX1, Vector, Phazer)? or from two strokes as well ?
Ffbsy
clutch
only the other 4 stroke primary's will work, the ones that cam on the 2 stoke do not have the cut out for the weights to swing out. If you want you can use the 2 stroke primary scheaves but you will need the spider out of one from a four stroke. Secondary is nytro only
