snownutz
I have an 08 RTx, installing a 144" OFT kit and a backcountry track. Was wondering what the best fit would be and what the best bang for the buck is.
scmurs
snownutz said:I have an 08 RTx, installing a 144" OFT kit and a backcountry track. Was wondering what the best fit would be and what the best bang for the buck is.
Hey snownutz. Your 144" kit shipped today. Thanks again!!
Scott
NLVMAX
Avid Products Drivers 2.52" Pitch 9 tooth 1.0625 Axle Size
http://www.avid-products.com/3inch_pitc ... rivers.htm
YamYboY
^^^^^^^^X2
snownutz
Awesome! pulling the skid off tommorw. Can't wait to see it. Thanks again Scott
stopdropanroll
YamYboY said:^^^^^^^^X2
x3
bagadonitz
x4
You are going with the same setup as me. The bits are great quality, you will be happy. I'm half way through the install with the tunnel extension in place already.
I've taken my skid down to its pieces to clean them up, polish and paint.
snownutz
Will I have to modify the rail tips to run those drivers, want to send rails out to get powder coated but I don't want modify them after there coated.
bagadonitz
I have inquired a lot on this subject and the best I can tell is that this was an issue on the 09 and up due to the different approach angle of the rails. On my 08 RTX (and yours as well I assume) this is not an issue and if I'm not mistaken, there is ample clearance.
http://www.ty4stroke.com/viewtopic.php?p=671932#671932
snownutz
Thanks I will keep my fingers crossed.
arteeex
snownutz said:Thanks I will keep my fingers crossed.
It's tough to ride that way.
The test is to undo the springs and shocks so you can move the skid thru its range of motion. I skipped this step when I could see 3 - 4 cm of clearance between the drivers and rail tips on my '08. If you do the right thing get back to me should you find a problem.
snownutz
Just ordered a set, last purchase is the track.
