pay2play
Not good. Tell me that I just need to replace a bolt...please. I checked the threads with another bolt and the threads seem fine. I was torquing down the primary "cover " to 14 nm with an inch lbs wrench I just bought at Harbor Freight. I used a converter on the web to 124 inch lbs from 14 nm that I found in the FAQ link. What do you think. I need some expert opinions.
Lman69
Guest
- Nov 5, 2013
Just replace the bolt. The stretching probably happened in dead space. Good thing you didn't snap.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I would run a tap
pay2play
I would run a tap
Even if a different bolt threaded in by hand with very little or normal resistance? I don't have a tap and die set. Just wanted you to know that there didn't seem to be messed up threads. Thanks for the feedback!
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I would recommend getting a better quality torque wrench, one tool I wouldn't cheap out on. Good thing it didn't snap off, if you can hand thread in different bolt I would think your fine.
pay2play
That torque wrench is a bummer. I read reviews for them and they weren't bad. Oh well. Glad it isn't snowing!
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
This happend to me a week ago. Tightening the primary cover. No problem with the threads in the clutch, just replaced the bolts.
Grimm
There maybe nothing wrong with your torque wrench. The bolt may have just been tired/weak. Just replace the bolt...you'll be good.
pay2play
I haven't looked into buying the bolt yet, do they come in a set of six? Thanks for the reassurance!
Grimm
Just buy it from a good hardware store and buy a high grade 8 or 10 bolt...a lot cheaper than Yamaha. The bolt size likely M5, M6 or M8.
pay2play
I pass by a fastenall shop on my way to work, any idea off they sell retail?Just buy it from a good hardware store and buy a high grade 8 or 10 bolt...a lot cheaper than Yamaha. The bolt size likely M5, M6 or M8.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Fastenal will prob want you to buy a box of them haha 85 cents each at port yamaha
pay2play
Cool, I can swing that, lol
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
The bolt size is M6x30 mm. I replaced them with 6 MC6S 8.8.
