basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I need there phone number got a few quick Questions Thanks!!
You'd probably get just as quick a response by asking your questions on here. Seems everyone has purchased at least one thing from them.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Im trying to order a arms and it says 09 shorty and all 10 and up. well I got a xtx
basic700 said:Im trying to order a arms and it says 09 shorty and all 10 and up. well I got a xtx
09 and up shorty and XTX are the same
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Do the New a arms come with New hardware or should I order New bolts and lock nuts? Whats your sugestion
yzviper366
Arms only come with the plastic bushings for the a arms nothing more. Is there something wrong with the bolts u have? If not why waste your money on new bolts?
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
My top a arm where it connects to the spindle the bolt keeps coming loose and egged out the hole, my cousin welded the hole shut and re-drilled it and I put it together. after 300 miles the SOB came loose again. Do I need a new spindle?, or new lock nuts and RED locktight or what, im getting tierd of this. its only the right hand side
yzviper366
I would get a new metall bushing and new bolt and lock nut and atleast use the medium lock tight
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
New metal bushing? For what
Dr. FeeLGooD
yzviper366
Well if you have taken the arms off before you will know there is a alluminum bushing that goes inside where the arm bolts to the frame look on a parts blow up u wwil find it
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
I currently have oilight bushings installed from ulmer. I Just ordered skinz a arms from oft yesterday im so excited
Tyloooor
Same thing happens to me (with bolt and nut coming loose on top of the spindle) went out and bought a new nylock nut and bolt and used blue loctite
