FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
I have 2 machines that need driveshafts and bearings due to spinning.
I found the Nachi 6009-2NSE9 mentioned.
Appears to be a fair choice. Operating temperature range -5f to +200f
RPM range is more than we'll use.
Can not find the comparable FAG or SKF for comparison.
What is your preferred replacement bearing and why?
justinator
You cant go wrong with any of the quality bearings like koyo, nachi, skf, fag etc. I replaced my factory bearing with koyo as it was convenient for me to get. I would not of hesitated to use any of the others mentioned. Just stay away from any chinese or no name bearings and you should be good.
Turboflash
- Mar 18, 2019
- Southern MN
https://www.ebay.com/itm/6009-2RS-S...070085?hash=item5b4bffa905:g:VvwAAOSwanhbjaUyI have 2 machines that need driveshafts and bearings due to spinning.
SeX Viper
- Mar 22, 2017
- Minnetonka, MN
- 2002 SX Viper
2014 SR Viper RTX
I work at a national bearing distributor and that is less than half of my cost on an SKF bearing, pretty sure you will be getting a counterfeit if you buy from this seller. Go to a real bearing distributor if you want to get something quality. SKF is the best but you will pay for it. Koyo and Nachi are also good choices but at a better price. I have been selling this stuff for 10 years and put Koyo in mine.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Happen to have a Koyo part number & spec link?
SeX Viper
- Mar 22, 2017
- Minnetonka, MN
- 2002 SX Viper
2014 SR Viper RTX
6009 2RS C3
Not trying to promote my company but here is a link https://www.motionindustries.com/productDetail.jsp?sku=00048747, you will probably get a better deal if you call your local branch rather than buy it off the web site.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
I like the Koyo -22f to +200ft operating range of the Koyo 6009 2RS C3
https://www.applied.com/c-brands/c-koyo-corp-/60092rsc3/Single-Row-Radial-Bearing/p/102192461
Turboflash
- Mar 18, 2019
- Southern MN
That's all about the grease in it, not the metal parts of the bearing.
Just get some Shell Aeroshell #7 grease and change out whatever is in the bearing you buy. https://www.lubexcel.com/repo/docs/A17-3271-FT AEROSHELL GREASE 7.pdf
-73 degC to +149 degC for opertating range. (That's -99 degF to 300 degF).
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
what about this?
https://www.bocabearings.com/products/smr6009c-2ys-c3-3-mg2-8037
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
You're running ceramic bearings?
Turboflash
- Mar 18, 2019
- Southern MN
Ceramic balls only, rest is all 52100 chrome steel (stainless). $161 each!
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I am thinking about it. They should last the life of the sled. Besides cost, is there a down side? Maybe someone with more knowledge than me on bearing applications can chime in.You're running ceramic bearings?
Get that thing locked to the shaft and be done with it until you need a track........
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I just asked for some info from the company that supplies these bearings. They do not recommend ceramic hybrid bearings for any type of shock load or vibration. They say it would fail quickly in a snowmobile drive shaft application.
oh well
oh well
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Kind of what I thought, but didn't have any real experience other than a bicycle application.I just asked for some info from the company that supplies these bearings. They do not recommend ceramic hybrid bearings for any type of shock load or vibration. They say it would fail quickly in a snowmobile drive shaft application.
oh well
Tried ceramic bearings in a bicycle bottom bracket (crank arm assembly). Wore out in less than one season. Never again.
Went back to quality steel bearings, Shimano Durace. Three years and still solid.
Can't imagine baked clay, being better than steel, in these applications.
slimjim2525
Yeah, ceramic will never work, they are correct. I do orthopedics, and have done several thousand hip replacements. Tried ceramic heads for a very short period, as I had several of them disintegrate into powder. It was ugly.I just asked for some info from the company that supplies these bearings. They do not recommend ceramic hybrid bearings for any type of shock load or vibration. They say it would fail quickly in a snowmobile drive shaft application.
oh well
