Jord05
- Mar 21, 2016
- Hepburn
- 2014 viper mtx162 mcx190 turbo
How much movement side to side should my secondary clutch have on my viper Xtx 2014 ,? Also IM just installing my ulmer clutch kit but can't get my Allen screws out of my weights scared to strip them out, should I just let them soak in wd40 and hope they come out?
Do you mean in and out on the Jackshaft? That is normal. It's a floating secondary. As for the weights someone may have used the wrong Loctite on the screws. Try a heat gun but don't use propane. Too hot.How much movement side to side should my secondary clutch have on my viper Xtx 2014 ,? Also IM just installing my ulmer clutch kit but can't get my Allen screws out of my weights scared to strip them out, should I just let them soak in wd40 and hope they come out?
Jord05
- Mar 21, 2016
- Hepburn
Yes in and out, and thank you I never think of using heat on seized #*$&@ always slips my mindDo you mean in and out on the Jackshaft? That is normal. It's a floating secondary. As for the weights someone may have used the wrong Loctite on the screws. Try a heat gun but don't use propane. Too hot.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
