Matthew457
stubb111
nope....that is metal tape for ductwork will burn off right away. what you want is listed below from ROYAL DISTRIBUTING in Canada PN A02-289183 (Moose Racing Adhesive Heat Shield) pg 257 spring & summer catalogue.
Matthew457
Really!? Wow I'm pissed I bought it now, wtfnope....that is metal tape for ductwork will burn off right away. what you want is listed below from ROYAL DISTRIBUTING in Canada PN A02-289183 (Moose Racing Adhesive Heat Shield) pg 257 spring & summer catalogue.
Matthew457
I think it'll be alright, this is after like 2 minutes of a lighter being on the metal, and the second picture is the black #*$&@ just being wiped off. I think it'll work pretty good. There no way its gonna get that hot back there.nope....that is metal tape for ductwork will burn off right away. what you want is listed below from ROYAL DISTRIBUTING in Canada PN A02-289183 (Moose Racing Adhesive Heat Shield) pg 257 spring & summer catalogue.
jimbur
- Aug 16, 2013
- Bernville Pa
- 09 NYTRO XTX
14 NYTRO XTX
08 NYTRO RTX
07 PHAZER
- Pa.
I'd try it . Also says 260*f
No way it'll be that hot .
Matthew457
Yea, I feel pretty safe with nothing on it so this tape will just be there for the "just in case."I'd try it . Also says 260*f
meskie
You'd be amazed how hot it can get on a long run down a trail.
Matthew457
But I doubt it will melt that can right though the plastic, expesially if there is gas in it, then that's impossible. I have no worriesYou'd be amazed how hot it can get on a long run down a trail.
meskie
So what happens when you use the gas? You should be ok your turnout is better then the muffler off my turboBut I doubt it will melt that can right though the plastic, expesially if there is gas in it, then that's impossible. I have no worries
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
My buddy bag cough on fire back there when he had his stock Nytro. So yes it does get hot after a long ride on the lake. Sure does for a nice smoke show.
Matthew457
On an xtx with turnout?My buddy bag cough on fire back there when he had his stock Nytro. So yes it does get hot after a long ride on the lake. Sure does for a nice smoke show.
Throttle Jockey
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
You could simply get a thin piece of aluminum about 1/16 " thick maybe 10" long and just higher then your turn out. Bend a 1" 90 degree bend on the bottom and the cut into the bend 1" where you want to make the other bend into a L shape. Now use the 1" lip to rivet to the tunnel under the gas can. All the protection you will need. Here is a picture of what I did . You will get the idea even though you can't see the bottom 1" bend. The other piece of aluminum is to protect the belt bag under neath.
Matthew457
Nytro-glycerin
- Dec 13, 2014
- 2010 Nytro XTX Black edition
I bought the yamaha saddle bag gas cans because no one could give me a deffinite answer to if what you did works. SO, if you could please keep us updated on this and how it works, I would appreciate it. I hate the yamaha bags so much that I will buy this same set up your using if it works out.Got the can taped up and hopefully she will work great!
Cheers
