fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
I can get a set of sly dogs for a decent deal with mounts kit for a burro/ phaser and the other kit just says arctic cat.
Wondering if the arctic cat mount kit will work on a xtx 15.
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
- 2015 Viper MTX 162 Turbo
Back up sled AC M7
If the kits are for a '12-'16 proclimb/procross then yes. If they are for an F, CF or M-series then no
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
Back up sled AC M7
I believe what you have there the 04-b001 should look like this correct? these are for the old arctic cat chassis
The new Procross/Viper use a 04-b001-3 that look like this.
Edit: If in doubt call Sly dog
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Bingo!!
It's the old kit that I have. I guess I'll have to come up with a kit for the viper/ procross.
That's why I love this site.
Ask a question, get an answer fast.
Thanks!!!
Thanks!!!
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Ok next thing is where can I get a set of viper sly dog mounts in Canada.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Fiddlers, what skis came on your viper. If you have the 14 Tuners, the rubbers are the same, but you have to trim the wrap down edge off the bottom. If they were the 15 Tuners, then the rubbers will work stock. You can use the stock bolts and shim washers (as necessary to fill the saddle). Only thing the kit comes with is the bushings, bolts, and rubbers. Bushings and bolts will work, and your stock rubbers may work with a little modification. At the most, all you should need is rubbers for a set of 15 Tuners and you should be good to go.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
I have the xtx le with the cat mountain skis.
I haven't had a chance to Check out the mounts and rubbers but will hold off on buying a mount kit until I get to check it out.
I'm thinking now that with the nytro,cat, and stock mounting kits I should be able to make up something that works.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Spindles were the same either way. If we can get Yamahaguys to chime on on this we will know if the cat mountain ski rubbers work since he put Slydogs on in place of his cat mountain skis.
Yamahaguys?
Yamahaguys?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I think you'll find that you can use the existing hardware and rubber from your XTX(nut,bolt,washers,rubber,spacers) If you have the AC mountain skis the rubber will fit very well once you cut the fingers off the bottom of the rubber. All the Slydog skis are the same they just change the bushing in the ski so that so fits the bolt diameter correctly. Those bushing you can see above in the pictures that TrickyNick posted and you might need to get them from Slydog. I can post a picture tonight of what you need to trim off the rubber
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Right on, perfect.
yamahaguys,
I see you have the 8'' skis.
I got the 7 ''
What carbides are you using and how are they on the trail?
yamahaguys,
I got the 7 ''
yamahaguy
Ride SAFE
- Apr 20, 2014
We use the cheapest carbide (4inch round bar) slydog has and we usually get 2 + years out of them. They work fine when we hit the trails , I think the extra tall keel has a lot to do with that. You might want more carbide if your on the trails a lot?
All those fingers sticking up on the bottom of the rubber need to be cut off flush or you can use a slydog rubber like the pictures above that Trickynick posted.
This rubber is from a 2015 XTX LE that came with cat mountain skis. Once you cut those fingers off the rubber will look just like what you would find on a 2015 Turner ski.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Will try this.
Thanks guys!!
Thanks guys!!
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
