fasteddie
Are the super tip weights exclusive to Ulmer? The reason I ask is I have Ulmers stage 1 kit but now added the Hindle full exhaust and im at 9300 rpm not sure where the rev limitter is at but I must be close. I need to add weight to the tips. Does yamaha sell the washers for adding weight? I would order from Ulmer but I need for this weekend. I did have the whole kit but cant seem to find the extra weights.
Kirkdking
I got loads of weights there but they wount make it to u by the weekend
You're right at the rev limiter and a little past peak hp. I would go to the hardware store with one of your weights and pick up some 1 gram washers that will fit an M3 screw. I'll bet 1 gram on each tip will be just right but you may need more. If you don't have a scale, Harbor Freight sells gram scales for about $10. If not, buy a couple of different size washers and experiment til you get it down to 8900.
HURRICANE
we have lots of washers for the supertips.Give me a call and I can send some to you
