Jona$
Master
How do you now that you got the right tdc when doing timing? i mean you get it 2 times at the crank at one turn on the axles, how do you know you set it at intake and not exhaust, both gives tdc 1,4.. tried both but sled dont start got fuel and air. got it start a few times ran really rough and shut down after some seconds and got code 14.. but the sled should start even do the pressure sensor dont work?
the valve clearance was this intake 1-4
cyl 1 0.15 0.20 .020:::::::::::::: cyl 2 0,20 0,20 0,20 :::::::::::cyl 3 0,20 0,20 0,15 :::::::::::cyl 4 0,15 0,15 0,15
Exhaust
cyl1 0,30 0,30 :::::::::::::::::: cyl2 0,25 0,25::::::::::::cyl3 0,20 0,20:::::::::::cyl4 0,20 0,15
intake says 0,11-0,20 so im good at intake
exhaust says 0,21-0,25 a bit over and a bit under, but not for the engine to not start ?
Exhaust
