tippmannator
Got a 2013 nytro xtx....stock track is 144X1.75....what is the tallest lug height I can run without major mods?
tippmannator
Anyone?
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Stock track on the nytro was 1.25", to put a 1.75" track on you had to remove tunnel protectors. A lot of guys including me did this before Yamaha's offered it as an option. With that said I believe you can put a 2" track on there, I remember seeing guys doing it way back when everyone started doing the 1.75" track swaps.
tippmannator
2013 nytro came with the 1.75.... so If I remove thw tunnel protectors I can go 2 inch?
radianguy
- Jan 1, 2007
I know that, tunnel protectors are not in your sled.2013 nytro came with the 1.75.... so If I remove thw tunnel protectors I can go 2 inch?
tippmannator
Ok so I should be able to fit 2" lugs on a stck xtx?
walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
1.75 lug is an awesome crossover track!!!
tippmannator
Thats what I have and I like it.... but I was trenching out alot this winter.... want a bit more bite
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
I find my XTX trenches horribly with the limiter straps all the way out. If I pull them one notch then it changes the off trail characteristics totally! I hardly ever get stuck no matter how dumb of a move I pull, stop and take off wherever without an issue.
Before spending all that money I would try improving the approach angle by pulling the limiters one notch. It just sucks that it makes steering harder by doing so.
SteelerJim
You might want to post this in the mountain section. I think if you go down 1 tooth in drivers you can put 2.25 in it. Don't quote me though
striker606
I have a 2" on mine and love it. removed tunnel protectors and went with smaller drivers. I believe they are 8 tooth drivers
