kokonut
Anyone know if I can get a tunnel block off here in Canada? anyone here make them?
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
a lot of people are ordering small sheets of aluminum from McMaster-Carr and making them themselves. They are either covering the opening form on top of the tunnel or are placing the sheet above the tunnel protectors and riveting them in place. Do a search on here and you will see many DIY kits that are inexpensive and easy to do.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
Yeah I agree. Make a template out of cardboard then transfer it onto some sheet metal and cut it out. THen just rivet it in. That's all I did.
Made one last month. $12 for a sheet of aluminum and little elbow grease. Template, cut , rivet in that's it. Did mine on top under heat shield.
TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
I made mine also.....
I cut mine to fit under the tunnel protectors and riveted it on to the underside.....
I do only have the stock exhaust on my machine, but I think you could make it to go around any pipe....
SnoBird888
now if only someone had a 2d template so i could put it in a program and have a machine cut it for me! could prob make them for ppl for 30 plus shipping.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
This is how I fixed my issue.
http://www.ty4stroke.com/download.php?id=84936
cloead
- Mar 8, 2013
Sorry for my noob-ness but was wondering what the point of this is?
canoehead
- Jan 14, 2011
- NE, Alberta
It's a download of a drawing to make a tunnel block off.
cloead
- Mar 8, 2013
Lol I meant in general, what is the purpose of a tunnel block off
canoehead
- Jan 14, 2011
- NE, Alberta
The tunnel block off plate eliminates ice build up by preventing snow dust from hitting the hot muffler and rapidly melting and refreezing. I know longer carry an extra 50 lbs. of ice build up in my tunnel.
SnoBird888
u ride your nytro yet in fluffy powdery snow? look under the tunnel and see how much ice builds up and it comes through the top of the tunnel and builds up there as well. sometiems down the sides of the tunnel.
NS FX NYTRO
And sometimes get so bad that when you hit a bad bump it dislodges the ice and jams it between the side of your track and tunnel, making a noise as though you broke your skid in two!
SnoBird888
Yup those scare the #*$&@ otta me
