STORM-CHASER
FX Nytro, FX Nytro RTX, FX Nytro MTX
This machine is new from the track and skis up. It's more than a Phazer on steroids; it's a triple-cylinder, 130-HP powerhouse in a chassis that weighs about 560 lbs. WET. What the yellow camp did to their 2-strokers, Yamaha did to their 4-strokers. They tightened everything up and lightened it up and created this next-gen 4-stroke model. The result is a sled with about the same HP-to-weight ratio as the big-dog Apex. The difference is that the FX Nytro rides way different than the Apex. The rider sits higher and even more centralized. When we rode this thing we were impressed. The power and torque is excitingly pleasing and the machine feels and handles quite light.
The engine is the focus of the machine and puts out over 130-ponies. It's a triple-cylinder EFI and is different than the 120-HP version found in the RS Vector line. It is lighter weight than the Vector motor and also features Yamaha's E.B.R.S. which is an engine braking reduction system that provides more of a coasting effect when you let off of the throttle, similar to how a 2-stroke motor feels. It is less abrupt than how a 4-stroke generally feels in a snowmobile. I happen to like the engine braking of the Apex and other 4-stroke models once I'm used to it, and the Nytro still has it, but not as abrupt.
The chassis includes a completely new front suspension that is easier to adjust and allows flatter cornering. The FX Nytro did corner pretty flat on our initial ride. Here are some other highlights:
Sport rider-forward position
Hand warmers to the end of the bar
Electric start standard
Lightweight rear exhaust
Beveled tunnel
Wide running boards
Lightweight die-cast FX frame
Digital gauge
Lightweight one-piece hood/console
Available in a base version, 40th Anniversary trim, RTX with Fox Floats and a Mountain version.
The FX Nytro builds upon the Phazer styling and offers more power for those hungry for it. We saw something coming last year after the Phazer was introduced, but not quite like this.
Beveled tunnel
Wide running boards
Digital gauge
clicker_clit
What is the dry weight?. I see that it only has a 7.5 gallon gas tank. I'm also a little dissapointed in the price. When they brought out the phazer they has a somewhat reasonable MSRP. I can't believe that they have that much more into the FX Nytro RTX. I mean $10,699 for the one with reverse is over priced. They should have been around $9,500 tops.
4strokin
where are you getting your weight specs from?
STORM-CHASER
4strokin said:where are you getting your weight specs from?
http://www.maximumsled.com/absolutenl/v.aspx?n=48
4strokin
thanks wonder how much the Mtn. version weighs
markusvt
- Mar 5, 2005
7.5 gallon tank, what were they thinking?
clicker_clit said:What is the dry weight?. I see that it only has a 7.5 gallon gas tank. I'm also a little dissapointed in the price. When they brought out the phazer they has a somewhat reasonable MSRP. I can't believe that they have that much more into the FX Nytro RTX. I mean $10,699 for the one with reverse is over priced. They should have been around $9,500 tops.
STORM-CHASER
markusvt said:7.5 gallon tank, what were they thinking?
they must want to keep the wet weight down.
number1kyster
I hope its good on gas!
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Now they can sell you a 2.5 gallon jerry can for the back of the sled to get your 10 gallons like the old sleds and their wet weights will be down on the spec sheet. I want to see how the rear suspension works mostly.
STORM-CHASER
I sure am looking forward to riding it at a demo, not sure when they will have them in the demos
LEOPAJM
- Dec 28, 2004
Does it ride / feel more like a Phazer , or more like an Apex ?
donnyrhodes
- Nov 12, 2006
the small tank will keep me from buying it... Plus its $3k more then the Phazer Fx...
Phazer gets 80 miles on a tank and the light comes on but still has about 2 gallons to get some where so at 115 miles its empty and thats 80hp at 8 gallons of fuel.........
I see the phazer Fx is up to $7599 so my 2007 with 3 year warranty and studs for $5200 is still a deal........
craze1cars
Only 115 miles on a tank with the 80 hp motor? This is my biggest concern with the new Nytro. I'd think it's gotta drink more fuel than the Phazer. So sub-100 mile range maybe?
donnyrhodes
- Nov 12, 2006
Do the math 115 miles by 8 gallons thats about 14.5 miles to the gallon......
Granted I ride it hard, lake and trail so for a slow rider maybe 16 Mpg
But this is lighter and less HP...
donnyrhodes
- Nov 12, 2006
All the Big Hp sleds have 11 gallons or close to it....
I Like to be ridin and not thinkin about fuel till 100 miles
