Hey guys I just pulled my carbs off to install billet T.. Carbs came off no problem, put on the bench and pulled rack apart enough to squeeze T's in
I retightened rack. I went to check how the butterflies opened and closed
after installing T's.. What happened was the butterflies did not want to open or close freely, when I put more pressure they opened, but did not close.. I loosened rack seemed to open and close a bit easier, but still not right. My question is what else should I check?? I don't want throttle sticking when on the trail!! How tight should the bolts be?? When fully tight should throttle move freely open and closed?? or just leave the bolt "snugged"?? Thanks John
