Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
I do not know, I have not taken delivery yet lol
Bahr05
Bahr05 said:revster said:Dropping an XTX skid in
XTX shoxs suped up, maybe Hygear
Either Ice Age rails or Star kit
New track either BC 1.75" or Challenger 2"
Cutting out running boards
BNG!
I'm dropping in the RTX skid, shortening my XTX back to a 121" track.
15x121x1" Hacksaw
Woodys studs (LOTS of them) length TBD at this time
Bushman spindle kit
Powdercoat a replaced spindle
Polish the tunnel
Finish restoring the 1979 Enticer 300.
Change of plans... With child support and buying a house, the only mods the Enticer and Nytro will see is dust that settles on them.
fxnytroxtx
Guest
revalve my axis, stock shock linkage (front shock ) star set up bottoms too much, innovate MTXL A/F gauge, and maybe wrp seat
I might do a 128" relocate....going to add a ski mounted ice scratcher and some type of mod on the light pod to let the hot air escape when stopped...also adding SLP flowrites where the tuning fork emblems are on the top shroud...still on the fence about trail tank.
nytro11tom
Putting new motor in my bullet proof stock nytro.
fxnytroxtx
Guest
nytro11tom said:Putting new motor in my bullet proof stock nytro.
What happened?
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
newfie09xtx said:Thinking about:
-Star Suspension kit
-Block off plate
-Seat Jack
-some powdercoating
Change of plans after I realized my Ripsaw was ripped thanks to ice buildup! (oh well this helped me convince the wife I needed a new track lol)
-1.75 backcountry (tunnel protectors removed)
-Somemore powdercoating
-Grizz Gusset kit
-CR10EK's
-Exhaust donuts
-Redo tunnel shine
-Replace damaged decals
-Since I cant find a headlight cover I am going to try a 50% tint on my headlight.
stubb111
summer sled renos
2009 NYTRO XTX
Current set-up
motor completely stock, stock ripsaw track with 114 studs, stock ski with snowtrackers (semi) trailtank, yamaheaters with boost, copper donuts, OFT steering relocator, rebuilt front end (last year) Star linkage kit, fox float x evol front shocks, fox float center shock (to Star specs), Hygear torsion spring spacers, Excel over size wheel kit (8), 4 wheel axle kit (homemade)
Summer Mods
new sub-frame (gusseted), Skinz 42" front end, Mountain tech skid plate & vented dash, Timbersled mountain tamer kit with stock rails, float 2 center shock and float x evol rear shock, rad shim mod (homemade to help air flow with trailtank), re-build front shocks, re-polish tunnel AGAIN
Special Thanks to the following:
hibshman25 (used parts.....doubled the parts able to buy for the money)
Jason @ T.S. (parts & info)
Jon @ HG (info & setup)
Spence @ 2KP (parts)
Mountaintech (parts & info)
OFT (parts & info)
Robert @ Star (parts & infp)
AND ALL THE GUYS WHO POST ON HERE!!!
2009 NYTRO XTX
Current set-up
Summer Mods
OFT (parts & info)
UNSC_WARRIOR
Lots of work for me this summer.
Maintenance :
- New brake pads
- New carbides
- New hyfax
- New belt
- Replace brake lever switch
- Oils
Mods :
- Paint the hood and gas tank cover black (plastidip!)
- Get my running boards and spindles powder coated black
- Custom made front bumper
- Mountaintech skid plate
- Install deflector plate to cure "wet left boot"
- Subframe reinforcement
Maintenance :
- New brake pads
- New carbides
- New hyfax
- New belt
- Oils
Mods :
- 33K
