subaru2006
Whats everyone run with track tension on the zx2? How much sag in the track do you got? Do you measure by free sag or do you use a weight. Also post your drivers anti-ratchet or stock. Im just curious on what I should run mine at. Ive been noticing lately a weird wear pattern. I don't know if its because of it being to loose or not? If that's even possible. I run anti's and have around 1.5"-2" free sag. Track is also a crossover.
Subaru2006
Subaru2006
ZapeX2
I run stock drivers with 144" crossover track. I have about an inch of free sag at below freezing temps. I have not had any ratcheting at all. I suppose I could run it looser but without extros, I don't want to chance the dreaded ratcheting...lol...
kinger
That is about right, I run about 1.5" of sag in the cold. I set it to no sag at 70 degrees in the shop per ADB never had a issue. Good luck!
stomper
At first I ran mine fairly loose , Just a bit tighter than my stock pro action. Which was way too loose because the skid shrinks in the cold. but then I tightened it up a bit. I have about .75" sag in my heated shop. Seems to be good now
- 33K
