jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Hope to spot a MPI 180 kit pulley, 26 tooth. I have found the steel alternative that gates makes, wondering if I can just use one of them instead.
Gates P26-8MGT-20 Sprocket
PowerGrip and PolyChain 8M 8mm Pitch for Belts 20mm Wide - Price: $101.15; Number of Teeth: 26; SKU: 7708-2026
www.biedlers-belts.com
Isn't the 180HP level 28/28?Hope to spot a MPI 180 kit pulley, 26 tooth. I have found the steel alternative that gates makes, wondering if I can just use one of them instead.
PowerGrip and PolyChain 8M 8mm Pitch for Belts 20mm Wide - Price: $101.15; Number of Teeth: 26; SKU: 7708-2026www.biedlers-belts.com
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
No, the Yamaha Low altitude OEM had a 26 tooth lower for rtx/xtx. I just bought a different sled and already has the 28/28 for 3,500-6000 ft.
What altitude are you using the machine at?
I used to have a dynotech subscription. The 26 drive and 28 driven was 170 @9200 at sea level.
The 28/28 was 180 @9200 at sea level.
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Hp is irrelevant, looking at boost. We ride around 1100-1300 feet. My rtx is easily boosting over 7 psi on cold days with a 26 tooth lower. I don’t want to risk boosting more than 5 running 91 octane. So the 28 is out. It’s been bouncing off the rev limiter when I punch it seeing 9300+ briefly.. Running Ulmer‘s clutch kit. Added heel wt per his recommendation which helped but seems to want to under rev once shifted out. This is all going to change a bit on the 2013 xtx with 1.75 track I just bought. Any suggestions on clutching that?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
That 26 tooth sprocket won't fit, the backside needs to be machined to gain clearance on the seal holder.
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Options? Need a pulley, asap. machine the one I ordered?That 26 tooth sprocket won't fit, the backside needs to be machined to gain clearance on the seal holder.
