Looking for a decent pair (left and right) stock coil springs for rear skid of my 21 Tcat, part #'s 3704-380 and 3704-381. Previous owner sacked these out a bit I think.
Thought maybe somebody had upgraded to some big boy springs and had their stock ones kicking around they'd let go cheap?
If that isn't what you are looking for, I have a pair of take off torsion springs from a 2015 Yamaha SR Viper that I had. The part numbers that you referenced are "100DEG-18.5LB". The ones from my 15 Viper are "90DEG-18.5LB". That means that they are the same spring rate as what you are after (18.5LB) but have 10-degrees more preload. That basically means that if you normally have the plastic adjuster blocks in the middle of the 3 positions, you could put them on soft one and likely have about the same overall spring rate. They were taken off with 46 miles on the sled.
