snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
my kit will be here this weds. and in the ad it says I will need to buy 2 upper pivot pins for the mtx and use them, I have the fx 121 and was wondering if I need to purchase these or can I use my stock hardware, any help with the install would be great, thanks.
RIKMAN
snopro,
you will need those two pins, they are smaller than stock. In fact, they are from a phazer.
Zipperno
They came with the kit to me atleast. Everyhting was in there bolt on and go.
No instructions though, but it is pretty obvious how to put it together. Remeber to retighten all bolts after a while.
MOUNTY
X2, the nylock nuts are not the best, had one come loose on mine. Could have been disasterous but in the end pretty minor.
snopro442
- Dec 10, 2007
- neenah wi.
I will wait until it comes and will go from there, thanks for the info.
multi sled
did you have the upper a arm heim joint come loose? that's what came loose on me,was riding at night,and probably rode for 5 miles befor i noticed it.MOUNTY said:X2, the nylock nuts are not the best, had one come loose on mine. Could have been disasterous but in the end pretty minor.
MOUNTY
Lower A arm
