Belt height on secondary?
sofunkingcool
Niagara, Ontario, Canada
Just wondering where you guys have your belt height set at on your secondary clutch? Mine is even on a 09 nytro fx. With a Schmidt bro stage 2 kit. Not sure if it should be sitting a bit higher like on my old doo? If so how do you adjust it all I can see is maybe having to add washers? Thanks
You want it to sit between 1.5mm above the edge to 0.5mm below.
Add washers to raise and remove washers to lower the belt.
Where would you go to get these washers? Order from a dealer or just a hardware store given the are the propper ID/OD and thickness
90201-061H1 0.5mm washers
90201-06037 1mm washers
