Super Sled
- Feb 25, 2009
- Summit X
At Hay Days yesterday I saw Yamaha's new hi fax, with Du Pont embedded material. I'm convinced they will solve the 2011 XTX hi fax issues. They will be about $60 per side but are expected to last 10,000 miles. They had a display with hi fax shown where they had a hi performance wide slide on one side and the dupont embedded hi fax on the other for 4k miles. Dupont hi fax had no wear. Will solve the issue with that sled, and make the hi fax last a long time on our sleds.
My concern would be will it wear the track clips out then. Something is going to wear with the weight Yamahas carry. 120.00 for hyfax is pretty pricey also. Did you buy a set to test Mike?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
If they will run 10,000 miles it will be worth it. Sounds good.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
These look really interesting. If they don't wear the clips like bottlerocket said and if you had wheels like the excell wheels these may just last a real long time!
I am looking forward to seeing how they do..
Super Sled
- Feb 25, 2009
- Summit X
I tried to buy a set but they had none to sell me. Expected at dealers by November tho. Ill be procuring a set tho. My track is not fully clipped, so well see of that makes a difference. They sort of inferred these work best with fully clipped tracks.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
If you have a poor setup they will wear out just as fast. For 40 bucks you could buy a set of ice scratches for the skis and be done with it. have over 6000 miles on the 06 with the same hifax. In the end it comes down to setup.
BombaPolaYama
Setup? What about the issue of the smaller diameter stock wheels than the other brands? Why introduce a pricier Hyfax when bigger wheels would do the trick? It seems like Yamaha is trying to fix the symptom of a design flaw rather than change the design.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Sorry...SOLD OUT!!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Bigger wheels means more pressure on the rails, I would rather replace hyfax's than rails, It all goes back to set up and conditions that you ride in.
- Jun 28, 2004
- Clinton, Wi.
I'll be running them on my Apex XTX. Bigger wheels, loose track, FAT man on the seat. I wiped out THREE sets in 1,400 mi. of UP riding. ALL in good conditions.I am still running the used hyfax that came on my used XpertX. With a 1.5 track , I might add
dilligaf
Sounds interesting. The $120 seems like a none issue in comparision to whats spent on other mods.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
APEX 06 said:If you have a poor setup they will wear out just as fast. For 40 bucks you could buy a set of ice scratches for the skis and be done with it. have over 6000 miles on the 06 with the same hifax. In the end it comes down to setup.
Gotta agree.
14,000 plus km trail riding on my 06 GT Apex. Original Hi-fax.
No wear the last 3 years to speak of.
Buddy owns it now. Still good to go for 2012.
Never used scratchers either. Put em on my 2011 for insurance though for river running.
sherlock29
SO are you actually gonna chase us down the river this year????hehe... next time your at the Hampton's stop in... stuff to show ya!Riceburner said:APEX 06 said:If you have a poor setup they will wear out just as fast. For 40 bucks you could buy a set of ice scratches for the skis and be done with it. have over 6000 miles on the 06 with the same hifax. In the end it comes down to setup.
Gotta agree.
BombaPolaYama
So all of the Yamaha riders who have switched to bigger wheels and all the other manufacturers are wrong?? I may be mistaken, but I don't see how a wheel that is 1/4" bigger diameter is going to put detrimental pressure on the rails.Teamblue4 said:Bigger wheels means more pressure on the rails, I would rather replace hyfax's than rails, It all goes back to set up and conditions that you ride in.
sherlock29
well i have 2 rails with bent tabs saying different. has to come down to leverage. 1 bolt 3" away from wheel, once you put more pressure on wheel(ie:larger diameter)=more leverage. this is why it is recomended to use doo's 2 bolt mount for extra support, or excell's mount.. also 2 bolt. one hard hit at the right place bends the rail...BombaPolaYama said:So all of the Yamaha riders who have switched to bigger wheels and all the other manufacturers are wrong?? I may be mistaken, but I don't see how a wheel that is 1/4" bigger diameter is going to put detrimental pressure on the rails.Teamblue4 said:Bigger wheels means more pressure on the rails, I would rather replace hyfax's than rails, It all goes back to set up and conditions that you ride in.
- 7K
