Chris600
I don´t really understand how the parts shall be on the outside of the discbrake and in the "gearhouse"
On the first picture nr 1 and 2 is called shims, after that comes 2 parts that should be greased. What are they? Beacause if you chack on the bottom pic to the right there is only shims and washer on the outside of the discbrake.
On the bottom picture to the left there is an O-ring ( nr 37) but that O-ring I can´t find on the upper picture.
The upper picture is from the service manual and the 2 on the bottom is from partsfinder
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I believe one of the two parts on the upper drawing are the o-ring and a small washer. The o-ring is usually stuck in the disk when you take it apart.
Chris600
Voda2000 said:I believe one of the two parts on the upper drawing are the o-ring and a small washer. The o-ring is usually stuck in the disk when you take it apart.
So is that the O-ring nr 37 on the picture below? Is that O-ring just on the wrong place on the parts finder picture?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
I'm pretty sure that nr37 is the o-ring. The shaft they show it going on is the same shaft that the break disk mounts to. I think that o-ring is there to keep dirt off the splines that the break disk mounts on.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Did you figure it out? I have mine apart so I could take a look at how it went.
Chris600
The O-ring should be at the outside of the discbrake...after the 0-ring a small washer that have that same outer diameter as the o-ring...and then a bigger washer that hold everything inplace.
- 11K
