I know this is not the best.. little sound issue and some other little quirks that may make you laugh but you get the idea...LOL
www.youtube.com/watch?v=MmS8m4h36yA
- Jun 28, 2004
- Clinton, Wi.
I'll be checking this now! Thanks for the video MrSled.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Should a guy check this adjustment wether you've changed anything or not?
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Mr. Sled, was yours out of adjustment? I thought I had read on here that you thought yours was a little slow compared to other Apexs?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I wish you had posted this video yesterday. I just did mine and had to read the service manual over and over again to try and get a better understanding of how to set the EXUP.
This should help those new to adjusting the EXUP valve, great job.
Redbeard
- Oct 14, 2011
- IN
Are you guys saying this adjustment may not be correct from the factory, or it gets out of adjustment over time?
Hi guys... yes it will get out of adjustment. Mine was out after 2500 miles, I noticed fuel mileage and top end loss.
I would think you would want to adjust or check after every season or at least check after the first season.
- Jun 28, 2004
- Clinton, Wi.
Probably my issue as well Tom. Chasing a never ending curve with clutching. Mileage and top end were WAY down this yr.
Viper_Dave said:Probably my issue as well Tom. Chasing a never ending curve with clutching. Mileage and top end were WAY down this yr.
Dave, let me know how yours looks when you check it. Actually I am curious about everyone's results.
- Jun 28, 2004
- Clinton, Wi.
I'll be sure to post results. Heading for Florida Friday so it'll be a week before I get to it.
Redbeard
- Oct 14, 2011
- IN
My sled's are put to bed, so it will be later this summer before I can get to it.
I will add it to my preseason list. hope to get some riding in tomorrow.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Do you believe that once you confirm the position of the EXUP valve the first time you can use just the diag screem to adjust your cables there after? If you need to see 0 and 180 on the diag screen I assume this is all you need to adjust the cable free play(?)
Preacher
Thanks Tom , just another obvious reason why this is such a great site
Thanks for the video Mr. Sled...I just did mine today and my notch was off to the right. Kept playing with the cable adjusters until it stayed centered on the hole when I cycled the key. All set now, sled has 2100 miles on it.
