mn.vipernut
Just got off the viper what on earth is a crankshaft spike? Riding in the wet stuff up pops the code hope is not crank bouncing around in the bearings.
I will be interested in hearing more about that.
fxnytroxtx
Guest
X2
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Look up OBD code p1338 is related to crankshaft position sensor. Could be a sensor issue, highly unlikely the timing chain has skipped or stretched enough to st off he code on a new engine. What were you doing just B4 the code popped?
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
OBD codes are standardized codes used across industry, they give you a starting place to troubleshoot.
You can look them up on the net.
09nytro
Wonder what caused that to happen !
bleedyamaha
- Sep 28, 2013
- Northern Iowa
roll over
Isn"t this the same guy that rolled his sled twice. Could that have anything to do with it. Sorry if it wasn"t you.09nytro said:Wonder what caused that to happen !
09nytro
I don't know if he did or not , but if he did then that may have something to do with it ....
Same guy
09nytro
Lol....right on !
mn.vipernut
Same guy, not sure LOL is appropriate. But I was riding layed to far over on the flat to the left side put it back on it's feet accelerated. ..code flash. If you are having fun riding aggressively this thing is going to go over and this whole notion of the oil not sumping is going to be problematic
09nytro
Your right ! That's going to be a problem for sure , I like to play around off trail as do most others and if you can't lay it over on its side with out a code coming up than why get the sled
Hope yamaha comes up with a fix!
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Tell the dealer because this is the first time I've heard of this so if you don't tell they won't know. You need to describe the circumstances also including how long it was on the side and how long it was upright before you accelerated away so they can reproduce the incident if necessary.
They could come back and tell you the sensor is bad and to get it replaced which is a possibility.
- Apr 14, 2003
- Hessel, Michigan
TestMaster said:Tell the dealer because this is the first time I've heard of this so if you don't tell they won't know. You need to describe the circumstances also including how long it was on the side and how long it was upright before you accelerated away so they can reproduce the incident if necessary.
Perfectly said TM
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
rolling a sled should have nothing to do with this. These sleds have to have the ability to roll. If you ride powder it is going to happen again and again.
- 14K
