powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Powder Lites large injectors for Stage 3 Nytro with Turbo kit that works with our Regulator/Fuel system setup.
3 Bar map sensor for over 15 PSI Boost required.
Need ProLite software to setup load when uploading new map.
Load VMax 4.49
Load Vmin 1.45
steps on load 0, 5, 10, 20, 40, 70, 80, 95 %
We reconmend Rods, engine work and good fuel for higher boost then 12 lbs at HIGH Altitude.
Have fun and add some weight to your clutch and crank out helix.
http://www.powderlites.com
250-836-4422
Load VMax 4.49
Load Vmin 1.45
250-836-4422
Lococoin
- Sep 8, 2007
- Edmonton, Alberta
- www.outlawatvclub.com
YOu mention that you recommend upgrades after 12 lbs at high elevation. I thought we could run close to 14 on pump gas before running out of fuel with the stock injectors? Just want to be clear on what the max boost you recommend for the stock injectors and 2 bar map sensor.
powderlites
- Sep 5, 2005
High Altitude Nytro boost
Guys unload at 6000ft and they can run up to 14 psi on most sleds but around here or in the whistler ,BC area you need more fuel and run lean at about 12 psi there because of ocean air.
Lococoin
- Sep 8, 2007
- Edmonton, Alberta
Thanks for the quick reply. Do you have some sort of chart/graph showing recommended boost pressures at different elevations? This would be for pump fuel.
jehay
- Jan 19, 2009
I tryed this set up the sled rips works will air/fuel is 12.0 full out at 17 psi
powderlites
- Sep 5, 2005
Lococoin
- Sep 8, 2007
- Edmonton, Alberta
What fuel pressure are you running? stock pressure of 45 or still cranking it up to 47?
powderlites
- Sep 5, 2005
Nytro Stage 3 Injectors map
Did some testing and this cleans up throttle response.
Pump correction is now adjusted for snappy RPM right from idle.
Timing is adjusted by adding a little more on bottom end.
Enjoy and we are working on improving some more this summer/fall.
Fuel pressure should be aboput 46 psi
250-836-4422 Dave
Pump 2%
Sensing 50%
Duration 1000ms
250-836-4422 Dave
Pump 2%
Sensing 50%
Duration 1000ms
- 37K
