tapp1
Saw this on MaxSled. Is it true that Yamaha is coming out with a kit? Anybody have a part no?
http://216.128.13.95/absolutenm/templat ... &zoneid=17
CaptCaper
- Jan 1, 2007
- Northern N.H.
Swell so your outer fingers freeze instead when you have to hold the end of the bars.
There is 2 posts on this kit with the bulletin from Yamaha.. It looks like the same kit from RSI which sells it for $39 Yami wants $99
stopdropanroll
CaptCaper said:Swell so your outer fingers freeze instead when you have to hold the end of the bars.
X2
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
You say $39.00.....
The elements are $40.00
The 8" grips are $20.00
The grip glue is $ 10.00
The whole kit form Port Yamaha is $83.96
tapp1
SnoWarrior said:CaptCaper said:Swell so your outer fingers freeze instead when you have to hold the end of the bars.
You say $39.00.....
Do you have a part number?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
SMA-HOTGP-HK-00 Hook bars
SMA-HOTGP-ST-00 Straight Bars
CaptCaper
- Jan 1, 2007
- Northern N.H.
You say $39.00.....
Missed that one in the rush.... My dealer wants $99.00..no tax here.. I guess with shipping Port would be similar to $99
06attaker
Where did you find these numbers online??
Can't find them anywhere to see what all this entails?
CaptCaper
- Jan 1, 2007
- Northern N.H.
There is another post on this kit in the Attak/Apex fourm. I believe there is a link to a bulletin from Yamaha showing the kit and instructions.
pete24
does it plug rite in? if it does then its worth it
- 7K
