ruffryder
Just an FYI. I replaced all mine this year, and here is all the information for replacing all the bearings and some seals.
Well, I have been in the process of replacing all the bearings for my Nytro. I ride an 08 MTX. I had it apart, so I figured I would just replace everything. Here is the info. Note, this is for models WITH REVERSE. The pto side track shaft was toast and the two unsealed beings felt worn. Honestly, I don't know what felt is, but whatever, it was apart, I had the time, so I changed them. Might of wasted money, might of screwed more things up then solved, but that is how I role!
I hope this is of use to someone, or at least I don't have to worry about loosing my paper with the information anymore.
PTO side - Jack shaft
6206 RD - KOYO - Double Seals
O.D. = 62mm I.D. = 28mm width = 16mm (this one is difficult to find)
I have had no luck at all trying to buy this bearing, besides the dealer. The 28mm is not in any of the product books, for the OD that is needed.
PTO side - Track shaft
UB205 NSK - Double Seals
O.D. = 52mm I.D. = 25mm width = 15mm (27mm shoulder with set screws, offset)
it looks like a NTN part# ASS205NR should work for this one.
Chaincase side - outer case - jack shaft
6205 KOYO - no seals
O.D. = 52mm I.D. =25 mm width = 15mm
Chaincase side - outer case - track shaft
6007RU KOYO - double seals (this one actually only has one seal, there is no seal between the bearing and the outer case cover (you can't see the missing seal side) I ran a double seal, just put it in, I will update if there are problems, but I don't think there will be any..
O.D. = 62mm I.D. = 35mm width = 14mm
Chaincase side - inner case - jack shaft
6206 KOYO - no seals
O.D. = 62mm I.D. = 30mm width = 16mm
Chaincase side - inner case - track shaft
TM205 NSK - Double Seals
Just an FYI. Can't believe there are 6 fricken bearings on this thing.
I got some info on the seals, probably do the same with trying to find them locally instead of having to go to the dealer.
Track Shaft - Chaincase - Hub / bearing holder
KOYO - MK035NI (23) I don't know what the 23 is for, but it is on the seal, so it is here.. haha
O.D. = 47mm I.D. = 35mm (shaft od) width = 6.5mm
Jack Shaft - Chaincase - Outer Cover - I believe that this is a high temp seal due to its proximity to the disc brake.
KCR - MK035F2 (12) again, don't know what it is for, but it is here
Jack Shaft - Chaincase - inside
KOYO - MK030N9 (3) same as above
O.D. = 52mm I.D. = 30mm width = 8mm
zammy
What did all of these parts cost you.
