NytroRtx
I have an 08 Nytro and looking to put a heated shield plug on it. I have a HJC helmet. can I just wire it directly to the battery?
Any help would be great, thanks.
Zakre
NytroRtx said:I have an 08 Nytro and looking to put a heated shield plug on it. I have a HJC helmet. can I just wire it directly to the battery?
Ye thats all you have to do, easiest and it will work when the sleds off just dont leave it plugged in lol
NytroRtx
Thanks, all wired up
Sled Dog
Did you install it with a fuse? If not it would be wise to add one and install on the positive side as clsoe to the battery as will allow.
thetruck454
I did not add a fuse and I kept blowing shields. I have a fuse now, and no problems
sofunkingcool
What amp fuse should be in there?
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
i use a 7.5 or a 10 amp.works for me
Use one of these from Kimpex wired directly to the battery. Drilled a small hole for it right beside the accessory plug.
