Need to no what rpms is wear the power is top and bottom thanks running roller secondary thanks top speed 118
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
10800 is the sweet spot for a stocker. Pulling anywhere around 10300 to 10500 out of the hole and building to 10800 as you accelerate will work well.
What should the top speed be on 2 inches snow on pond10800 is the sweet spot for a stocker. Pulling anywhere around 10300 to 10500 out of the hole and building to 10800 as you accelerate will work well.
tomanytoyz
R you serious , that all depends
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
I was thinking the exact same thing. Only about 100 different variables to consider there....
