well with 36000 km on the 11 apex xtx, the old girl needs the spindle bushings done. noticed the steering arm starting to wear on the housing on the top side. decided to add a shim washer on the bottom to hold it down a bit further. using a 1.25" id s cam washer for a transport.
did not use the oilite bushings i had saved from the kit when i did the front a arms as it did not have them for the bottom of the spindle. checked the other 2 kits/left overs i have and still no lower bushings. got oe ones again as i think they did last long enough.
