Dr. FeeLGooD
Looks like its bottoming out a lot. I would say it was too soft.
sideshowBob
Just started riding mine...no marks yet
but it shouldn't hit even if it does bottomLooks like its bottoming out a lot. I would say it was too soft.
I agree it shouldn't, Looks like it was an oversight. Can you relocate the rail to rail rod back some so its not going to hit it or you could Zip tied on a piece of hose or something as a bumper?
Dr. FeeLGooD
You would think for 20 grand they would throw in a chunk of hose lol. I was thinking I could do something like that. Strange thing is it was set too stiff from the dealer and was like that before I softened it. Rides better but there is still room for improvement. Maybe this could be caused from front shock too stiff?
Hard to say, I know the link skid do work together and you need to tune both shocks at the same time.
Dr. FeeLGooD
So I was under there to adjust front shock and I noticed the aluminum bar has a flat side machined in it for the entire length. This edge is facing forward. Maybe if it faced up it would clear the black rod. I will try this also.
sideshowBob
I am going to do the same to mine..
Flatlander SE
- Dec 29, 2008
- Lloydminster, Alberta
- 2018 Sidewinder X-TX SE
Just checked mine and it has the same mark (small paint rub on the rod). Going to rotate the aluminum crossbar also.
Thanks!
Thanks!
