Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Yes limiter pulled in to tightest setting. I am going to poke a hole and go even tighter now to get more weight on front. Center shock had NO tension on it. The steering will never feel heavy because of power steering. I might give up on this stryke ski and try the 5.7RYou said normal suspension adjustments.. did you pull your limiter straps up any from stock setting? I've always had to pull mine 2 holes to get any decent bite regardless of what i was using for runners
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Wait a minute, I just looked up this Qualipiece 12" dual carbide. dual-carbide-runner-12
These dual carbides like this are never going to turn and push in every corner no matter how much pressure you put on the skis. They are the problem, not the ski. Dual carbides push no matter the brand. The ONLY good thing about them is they dont dart. They pack with snow a push in all conditions. I quit using them way back when.
You dont need skis at all. You need different carbides to go around a corner. Dual carbides are only good for going slow period. No amount of tweaking is going to make them corner, and ANY ski they go on will push.
earthling
I have a new to me 22 LTX GT eps that I am trying to get rid of push. Might need to switch skis up. Am running 12” offset carbides from qualipiece and a lot of weight on front skis plus normal suspension adjustments that I do. Will need to start testing other combos but I had hoped these Stryke skis would be better. My last sled was a 2019 xf9000 and I had it dialed in with. Pilot 5.7r race skis.
So my question is do I swap skis and to what? I have some pilot 6.9s to try again as well as those 5.7r. I was really hoping the Stryke ski was decent since it’s apparently comparable to a cat ski but so far not feeling it even with big carbides.
I have over 30,000kms on this chassis over the years so am no stranger to making it handle well.
I see some people have swapped to mountain cat ski with deeper keel, how does that compare to a pilot? I have $300 in these carbides already so would be nice to be able to reuse them.
Which qualipieces model is this?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
You shouldn’t have to shorten the limiter strap beyond factory settings. You kill suspension travel the sorter you go, like said above it’s the carbide not the skis causing the push.Yes limiter pulled in to tightest setting. I am going to poke a hole and go even tighter now to get more weight on front. Center shock had NO tension on it. The steering will never feel heavy because of power steering. I might give up on this stryke ski and try the 5.7R
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
X3 Dual carbides no good.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
I had Woodies version of dual carbide runners on my 2000 SRX. In fair weather I was able to turn the handles 45 degrees left and right and it would still go straight unless your slammed the brakes. lol
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Aggressive on Stryke skis here. Love it.Snowtracker Aggressive carbides is the route I'd go.
Has anyone used them on the Strike yet? Hopefully they work better on the Strike ski than the Cat ski. I refuse to run them on the Cat ski, but work really good on any of the Doo skis I know as thats what I currently run.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
12 inch mission offset, I believe Knapp posted the link above.Which qualipieces model is this?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
Hmmm...maybe that's it? I have never run dual carbides as this is the first time, these are the offset ones that I heard were good. I do agree they dont dart. I will deal with a little dart if I can get rid of the push! Typically I have run long single bars, like Woody's ace. Sounds like I need to go back to one of those and try before swapping skis. In theory these are single keel so should work like a Cat or 5.7R ski.Wait a minute, I just looked up this Qualipiece 12" dual carbide. dual-carbide-runner-12
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Don't seem to offset to me? The stock stryke carbides are offset and seems better to prevent snow packing up in between.
Qualipiece 12"
Stryke Stock Carbide
Qualipiece 12"
KnappAttack
- Feb 19, 2004
- Welch MN
Exactly, when I heard offset, I was thinking like the stock cat offset carbides. Aren't the stock carbides offset like the Cat ones. Even they would be better than these dual carbides.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Maybe these ?
Turboflash
- Mar 18, 2019
- Southern MN
DittoX3 Dual carbides no good.
earthling
A single carbide will dart. The Qualipieces adventure is their version of the snowtracker (anti-dart). It has the plate in front of the carbide to reduce darting (similar to snowtracker) but lacks the correction plates (u shaped plates) and the profile is shorter so it should not require any suspension adjustments over stock.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
YEs this is what they Mission offset look like, just like the stock carbide except 12 inch total carbide. The pic on Qualipiece with the link above is not correct, I am running the offset ones.Don't seem to offset to me? The stock stryke carbides are offset and seems better to prevent snow packing up in between.
Qualipiece 12"
- 8K
