ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Stock spring with 70 daltons, 3200/3300 or soEngagement rpm?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Im sure your "kit" has a primary spring too??my ulmer kit holds rpm at 8800 for as long as I hold it, doesn't drop at all with stock 35.
I am fairly certain the stock primary spring is abit too low, and causes this laziness...Will be trying another primary spring a tad higher.
I think the 37/33 is a really nice helix, and may just try that one myself.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
this is the reason I wont buy a kit, while some work well, I always am so anal about things I end up having to tweak the kit and then you are stuck not knowing rates,angles ect.....At least in my own testing I write everthing down and know which way I need to go to get there.Never drops in any condition?? What weights does he run in his kit? I think he use to run super tip
Great kit if rpm doesn't drop but I've never had luck buying kits. Always had to make adjustments myself after buying a kit
But I think a spring is needed with these Dalton weights, at least to ge the bottom to be snappier....they pull like freight train everywhere else already, but they swing heavy IMO with that curve so that stock light primary spring is just not enough.
Dan
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
STM weights and a new spring. Stock secondary. I don't waste my time testing in crap conditions, hard pack groomed snow, rpms hold as long as I hold it. His setup works for me. Just want to find a good helix to try and get a little more. Then it'll be time to flash.Never drops in any condition?? What weights does he run in his kit? I think he use to run super tip
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
Dan
Did you find out the start and finish rate on the stock spring?
DMCTurbo
- Nov 12, 2005
I do have a new spring which came in ulmers kit. I've never felt the laziness your talking about. Actually I think your the first to mention it to be honest.Im sure your "kit" has a primary spring too??
Dan
newtron
- Jan 2, 2010
Ok thanks for the conditions u see these rpms
Ulmer knows his stuff
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
exactly my point.....weight alone(with stock spring) is why I want another spring to test with.I do have a new spring which came in ulmers kit. I've never felt the laziness your talking about. Actually I think your the first to mention it to be honest.
Allen knows his stuff, and surely has a good spring/weight combo.....and so you have no split second of laziness on bottom, likely a 125 to 130 finish or maybe more.
Dan
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
I'm testing big venom with td flash and quiet this weekend. See if it holds r's @ 6/1 with pocket machined.
DMCTurbo
- Nov 12, 2005
No laziness that I can feel, low engagement and very smooth upshiftexactly my point.....weight alone(with stock spring) is why I want another spring to test with.
Dan
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Here's my take on what you guy's have going on. Flatter profile weights give a sluggish feel down low. Product of the profile. You will not be able to completely get rid of it. Rpms dropping in longer runs is from too low total force on primary spring and helix angle. To achieve a good setup with flat profile weights you need stiffer spring, steeper helix and more secondary wrap. It will feel good down low to midrange but will suffer a little top mph even though rpms will now be stable. I personally prefer a more aggressive weight for trail riding. Better overall performance and quicker throttle response. Just my opinion and trying to help you.
newtron
- Jan 2, 2010
Thanks shagman.
Like u and dan said, the primary spring is the biggest culprit for the rpms dropping on a long pull in our setup.
newtron
- Jan 2, 2010
How much shorter is ulmers spring compared to the stock spring?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Daltons are not very flat IMOHere's my take on what you guy's have going on. Flatter profile weights give a sluggish feel down low. Product of the profile. You will not be able to completely get rid of it. Rpms dropping in longer runs is from too low total force on primary spring and helix angle. To achieve a good setup with flat profile weights you need stiffer spring, steeper helix and more secondary wrap. It will feel good down low to midrange but will suffer a little top mph even though rpms will now be stable. I personally prefer a more aggressive weight for trail riding. Better overall performance and quicker throttle response. Just my opinion and trying to help you.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I wish someone would chime in with stock spring rates....
Stock is a gold/red/gold (90501-550a7-00)
I have spoke to a few people and we are guessing its around 50/103kg. But not certain.
Dalton has a few Im eyeing up at the moment based on this.
Black/Green is one of them.....57/129kg
