bluegrass
- Mar 6, 2007
so I think I my need to replace my a arm bushing. I had play in the top a arm tighten the bolt up and a lot of the play went a way but I still have a small amount of play should you have a little or have no play at all also if I change the bushing out with iolite should I replace the bolt and the long collar to sled has 900 mile on it
SteelerJim
The stock bolts and collars will be fine. Just regrease them. If you have a welder weld the nuts to the subframe while you have it apart.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
You talking about the nuts for the lower a arms?SteelerJim said:The stock bolts and collars will be fine. Just regrease them. If you have a welder weld the nuts to the subframe while you have it apart.
Kirkdking
More than likely I welded my lower a arms nuts onto the sub frame makes it a lot easier for taking them off and putting back on..
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Make sure you use loctite on the threads when reassembling the front (even if the bolt uses a lock nut)
http://s589.photobucket.com/user/grizzt ... t=6&page=1
SteelerJim
basic700 said:You talking about the nuts for the lower a arms?SteelerJim said:The stock bolts and collars will be fine. Just regrease them. If you have a welder weld the nuts to the subframe while you have it apart.
Yes sir. I welded the nuts for the front of the lower A arms on the inside of the subframe so the bolt heads are now in the front below the bumper for easier access.
